Use this procedure to view FA interface configuration.
  1. To enter User EXEC mode, log on to the switch.
  2. View all FA interfaces (ports and MLTs):
    show fa interface
  3. To view FA interface configuration on ports, use one of the following commands:
    • View FA configuration on all ports:
      show fa interface port
    • View FA configuration on a specific port, enter:
      show fa interface port [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
  4. To view FA interface configuration on MLTs, use one of the following commands:
    • View FA configuration on all MLTs:
      show fa interface mlt
    • View FA configuration on a specific MLT:
      show fa interface mlt [<1-512>]
The following example displays sample outputs for the show fa interface command.
Switch:1>show fa interface
                            Fabric Attach Interfaces
INTERFACE    SERVER   MGMT     MGMT     MSG AUTH MSG AUTH  TCN   ORIGIN
             STATUS   ISID     CVID     STATUS   KEY
Port 1/1    enabled  0        0        enabled  ****
Port1/10    enabled  0        0        enabled  ****
Port1/6     enabled  0        0        enabled  ****
Port1/11    enabled  0        0        enabled  ****
Mlt2        enabled  0        0        enabled  ****
 5 out of 5 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the port 1/6.
Switch:1>show fa interface port 1/6
 1 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the MLT 2.
Switch:1>show fa interface mlt 2
Variable definitions
The following table defines parameters for the show fa interface port command.
Variable
Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
The following table defines parameters for the show fa interface mlt command.
Variable
Value
<1–512>
The valid range for MLT ID.
